Thread: opening pools
    Mar 2016
    salisbury nc
    8
    opening pools
    I have maintained my pool for 9 years and never closed mine.. so I'm helping some people open there pools..Most of these pools are green nasty swamps, the likes of which I have never seen before.. what's the best procedure (way) to follow to obtain clear water for these people.. Their Pumps will already be up and running..
    thank you
    Salteedog
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: opening pools
    Welcome to TFP, the best way is to test with a great test kit and use SLAM, check out the SLAM link in my signature below..
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: opening pools
    SLAM
    Pool School - SLAM - Shock Level And Maintain
    But I will warn you, some people will be very very resistant to pouring gallons of bleach in a pool. I tried to help my neighbor with his algae, but I absolutely cannot convince him that Clorox and chlorine are the same chemical. He is still struggling. I did all I could.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
