Results 1 to 8 of 8
Thread: Another New Tester Wants Comments
    Apr 2016
    Palmdale, CA
    2
    Good morning all. After years of struggling with an off-line chlorinator and then a brand new in-line last year I give up on chlorinators. I’ve decided to devote the time our pool deserves.
    Hi my name is Augie and I’m an alcoholic….I mean I’m guilty of neglecting my pool.
    A couple weeks ago Leslie’s told us our CYA was very high, I think it was over 150. We had not changed water in several years so we drained and refilled the pool. I started looking at you tube videos and came across the BBB method and this forum. I ordered a TF-100 test kit that I received yesterday. Here are the results of my first tests.
    FC 2 – CC 0.5 – PH 7.5 – TA 160 – CH 280 – CYA 0 – Water Temp 68 – 16,500 gal
    This pool is in the high desert of so Cal, full sun. Right now there is a solar cover on the pool.
    So here is my rookie assessment, based on my numbers I have to issues to work on high TA and low CYA. Using the forums Pool Math Calculator here’s what I think I should do:
    Raise the CYA with 92 oz of solid stabilizer. Giving it about a week to come up to a target of 40.
    Lower the TA to 7.2 by lowering the PH to 7.2 using 37 oz (volume) of dry muriatic acid. I can later raise the PH by up by aerating.
    Any suggestions? Comments? Thanks for reading.
    augie
    16,500 Gal In-Ground Kidney Shape
    Mod Squad pooldv's Avatar
    DFW, TX
    24,192
    Re: Another New Tester Wants Comments
    Welcome to TFP!
    Congrats in advance on having a great summer!
    You are all over it and on the right track! Every time your PH gets above 7.8 lower it to 7.2 with muriatic acid. This will in turn lower your TA. Eventually the TA will find equilibrium and your PH will stop rising. This usually occurs at 60-80 ppm. More here on that, Pool School - Lower Total Alkalinity
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,840
    Welcome, Augie!
    Congratulations on taking control and purchasing a proper test kit.
    You've got it figured right!
    Yes, target 40 on the CYA in case your pool isn't quite as large as you think, so you don't overshoot. You'll probably be happier in the 50-60 CYA range where you live, but you have a few weeks before things really heat up if you have to add more. If there are any trips planned this summer, leave room to use some pucks while you're gone.
    Just lower the pH to 7.2 and don't waste time trying to aggressively aerate. pH will bounce back up plenty quick all by itself, possibly overnight. TA will come down over time as long as you keep the pH in range. It lowers faster if you stay at the low end of safe, 7.2-7.5. Look for Muriatic Acid. It's a liquid. The dry acid adds sulfur.
    Don't neglect to raise the minimum and target FC levels after you add CYA. The first day isn't such a big deal, but from day 2 onwards, assume it's all there even if the stuff hasn't completely dissolved by then.
    For your bleach and acid needs, you might want to check out HASA. It's full-strength stuff in refillable jugs. You pay once for the deposit on the crate and jugs and after that it's quite cheap.
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Are using powered CYA? If so, I recommend putting it in a sock and hanging it in front of one of your returns. Give it a squeeze a couple of times a day and it will dissolve faster. The folks on this site are awesome. Welcome to the party!
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Apr 2016
    Palmdale, CA
    2
    Thanks guys. I can’t imagine trying to learn all this without this site. I have to go to work now but thank you all for the helpful comments! I appreciate your time.
    augie
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    29,235
    You go girl! It really shows that you have been doing some (quite a bit really!) AND you have a great test kit and know how to use it!
    How does your water look?
    When you post your numbers can you post like this please?
    FC
    CC
    PH
    TA
    CH
    CYA
    It is easier to read like this.
    Can you also put more info. in your siggy-pool kind, filter kind, pool size (gals), test kit, etc. THANKS!
    kim
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,350
    Welcome to TFP, you are all over it, nice job
    Sep 2013
    Charleston, SC
    535
    Quote Originally Posted by AugieAscot View Post
    Hi Augie. (Sorry, couldn't help myself!)
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
