Results 1 to 20 of 20
Thread: Is it worth the trouble?
    Apr 2016
    morgantown
    10
    I bought a home last year... which was a complete reno... still not quite done with it..
    But it came with a hot tub that was also neglected . 1998 sundance calypso. I filled it up after scrubbing and noticed that a pump didn't work. Ok no problem . Got a new pump and popped jt on. There are 2 areas I beliebe are leaking.... it's a foam insulated tub and I can't see where it's coming from. Started cutting into the foam just to look and ants everywhere! (Eek) .
    Before I continue . Is it worth my troubles and money to try and salvage? The inside looks new still . But there are spots leaking thst I can't see. So I do not know the extent of the damage ... Prob frozen pipes .
    Also. Are there people that would come and repair for me at a decent cost? I'm in central indiana
    Any advice?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Is it worth the trouble?
    Welcome to TFP
    hmmm, it will probably be cheaper than a new one but it can get expensive fast if you call the repair man. It will probably cost around 100 to get someone to diagnose it and see what the problems are..
    are the heater and controls working, that is usually the most expensive and hardest to get working.. if they are not you can replace the whole system for about 400 Replacement Hot Tub Control Systems Complete
    use ahh-some to clean all the nasty stuff out of it once you get it working, trust me on this one Amazon.com: Ahh-Some Hot Tub/Jetted Bath Plumbing Kitchen
    Chatabox's Avatar
    Apr 2016
    Queensland, Australia
    64
    It's so worth it! I was never a spa person before purchasing our new house. And I love mine so much. I'll use it more coming into winter now, but you won't regret it!
    Do you know anyone who might be able to have a look for you before calling out a repairman?
    5900 litre or 1558 gal above ground swim spa. Approx 5 years old and heated to 37 degrees celsius year round. Cartridge filter, ozonator, Nature2 mineral sanitiser, Aqua Health non chlorine based shock, Lithium Hypochlorite dosed at each spa usage. Filled using mostly stored rainwater from tanks, and town water when the tanks are drained.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Can't hurt to try to salvage the tub...mine has hobbled along for a few decades now The reason it keeps going is because i keep fixing the leaks There are some ways you can cut down on or eliminate service cost. In your shoes, I'd try, since you've already invested in the pump and I assume the boards good.
    How fast is it leaking?
    If you leave the whole thing turned off, does it still leak?
    If the pump and lines that are visible don't leak at all while operating, then run it for a spell to see if you can locate damp areas on ground or under shell.
    Next, try Marlig's Stop Leak for hottubs. Give Er a run and see if that stopped the leak. It will fix small leaks.
    If that doesn't work, and you've identified a jet area (or light) that's leaking, you can cut away the foam to confirm, then either call repair person to replace light or jet, or if its a line and you want to try to DIY use Plast-Aid, which will bond to PVC and repair.
    My last major leak was a cracked light lense. I had it replaced but some would be comfortable even doing this as a DIY. Part was $44 due to odd size. Certainly cheaper than buying a new tub
    Hope that helps give you an approach. My repair bills stay lower by isolating the problem and about 50% of the time its a DIY fix
    Ps. Guillens online is usually pretty good about aging old/obsolescèd diagrams and parts available.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2016
    morgantown
    10
    Quote Originally Posted by Swampwoman View Post
    The control boards seem to be working. Unsure about the heater. I'm going to try the fix leak and hope that works. Seems worth the 15 bucks to try! Thanks again!
    Ok.. update.. went out to check water level and the leak is apparently huge. Sunday the tub was 3/4 of the way full... today it's emptied out lol. Probably a drain leak at minimum right?
    Will fix a leak still work?
    Jul 2013
    Fletcher, OK
    3,353
    that is a pretty major leak, who knows where its at, you will need to add water again and start searching for the leaks, once you find them you will need to figure out which ones you can fix.. The hunt is on
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Cheaper source for Ahh-some: ahh-some - Newegg.com
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Okay, this sounds stupid but you'll be happy if I'm right: look inside the cabinet to make sure the drain tap is closed
    Confession: when I moved the hot tub to the house I'm in now, I kept trying to fill it all day and was certain the movers had broke a pipe. Turned out I hadn't close the drain valve Hope that's true in your case too!
    Helpful Links:
    Apr 2016
    morgantown
    10
    Haha I'm pretty sure it's closed I got all the siding off and there wasn't any water.coming.out of the spot I hook a hose to in order to drain... unless there's another drain tap that I'm unaware of which is totally possible ! I ordered some fix a leak. Working on getting into the foam as well so when it gets here I can fill it up snd see better.
    Apr 2016
    morgantown
    10
    I had some confusion. The circulation pump would be the little red one going into my Heater correct? I've got a Flo code showing up .
    Also. When I try n fill my tub thru the filter spot the water comes back out. Would thst be a clogged circ pump doing that?
    Apr 2016
    morgantown
    10
    Ok ... seemed to have found my culrput. Looks like a return drain line in the back left corner. Water was literally pouring out. Gotta figure out how to get enough space to work on it now lol
    Also. Next to my flow switch is a little black pipe coming out of the area that wires are coming out of. There is a little plastic tube hooked up to the top.. well its dry rotted and fell off .. Thinkin thst is prob what's triggering my flo error code.
    Anyone know what that part is?
    Jul 2013
    Fletcher, OK
    3,353
    if it is a 1/8 inch little hose it may be an air pressure switch, they turn the pumps on and off (and lights in my case) they do it that way so no water can damage electronic parts..
    Apr 2016
    morgantown
    10
    Ok got the bad piping cut out.. now the prob is that the foam all around thibgs is holding it so firmly that there's no ebough flex to line up my new piping and get jt into the fittings..... any advice for tight spot plumbing with no flex in the pvc?
    Apr 2016
    morgantown
    10
    The little tube is coming from the ozonator . Can this be bypassed?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Nickmyster16 View Post
    on my last tub the nipple at the ozonator broke off, so there is no telling how long I had no ozone. My new tub doesn't even have it. With an older tub it probably doesn't work anyway. So, with all that being said, just cap it off would be my suggestion.
    Support the site
    Apr 2016
    morgantown
    10
    Awesome. Also. Got a Flo code . I have great water flow coming out or circ pump... I know this because I had air bubbles flying thru before I found my little air leak. Got that sealed up and it seems the little thing that is supposed to touch the switch bounces back and forth even when solid water flow is hitting it. That sound like a bad flow switch?
    Jan 2012
    7,264
    Its pretty common to get Flo codes. If I don't fill our hot tub up thru the filter area it will have an air bubble or air block in the lines. Try pushing the hose directly in to the intake area and see if you can force water in the pipes that way.
    Apr 2016
    morgantown
    10
    Yep did thst with a rag wrapped around jt snd had watwr coming out jets on the fill up
    Apr 2016
    morgantown
    10
    It was the flow switch. Got new one on snd were heating up. Put my bromine reserve in and trying to balance. My ph and ta are high. Had to leave for work but seems I'm on my way. Question..
    Do u shock eith the floater in? I'm doing 3 step
  20. Back To Top    #20
    Sep 2013
    Charleston, SC
    537
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
