Results 1 to 9 of 9
Thread: Pentair ScreenLogic 2 iPhone app remote password
    Feb 2014
    Texas
    42
    Good Evening Troublefreepool Family.
    I'm experiencing an intermittent issue where my protocol adapter remote password stops working and I need to reset via the config utility. Wondering if anyone else is experiencing this issue.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pentair ScreenLogic 2 iPhone app remote password
    sorry I don't, but maybe this will bump it up and someone will see it
    Feb 2014
    Texas
    42
    Thanks
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    So all of the sudden your password just stops working?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I don't have any customers that really have a use for the password feature. You (a hacker), would first need the protocol adapters address to begin to cause any problems. I figure that's a good enough password right there.
    Factory Warranty Station for:
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    That was my thought, just disable the password all together... I've never heard of this issue though.
    -Brian-
    POOL BUILD
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    When ever something doesn't work with Screenlogic, an update, whether it is a brick update or your desktops' software update usually solves the problem.
    Feb 2014
    Texas
    42
    I thought the password was required when you wanted to connect remotely meaning not on wifi. Even if this was the case, I want a passwd so that someone can't remotely control my system.
    Dec 2014
    Riverside California
    482
    You have to have the system name for either remote or local connection. That is a pretty hefty password right there.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
