Thread: Best place to get flex PVC
    Dec 2015
    Krugerville, TX
    23
    Im needing to fix/update some plumbing and was going to go with flex PVC for the above ground stuff. Where is the best place to get 2" flex pvc? Should i get sched 40 or 80?
    20yr old,14k,IG,Plaster,Hayward Pro-Grid 60sqft, Hayward DE Separation tank, Hayward Multi-port Valve, Whisper-flo single speed 1.5hp pump,Hayward XL concrete pool suction vacuum, Polaris P340 (Leslies Pool model), Still working to get a test kit, Leslies Power Powder and Leslies 3" Tabs.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Best place to get flex PVC
    Sch 40 is good. I haven't bought any in a long time, but I used to buy flex pvc at a pond store.
    Jul 2015
    Gilbert,AZ.
    123
    Are you wanting to use flex because you see it as being an easier way to achieving your plumbing goals?
    Dec 2015
    Krugerville, TX
    23
    Quote Originally Posted by pool&spatech View Post
    For the most part yes. I am retro fitting an existing system at the house i just bought and converting the pressure non-booster line to a vacuum line. There is also an existing HVAC system that sits close which it preventing me from re-pluming the whole system. So for now I thought i best to run with flex. Im only going to be using about 6' which will be used on the new vacuum line and the existing main/skimmer line which is already flex from the 3-way valve to the pump.
