Thread: Jandy Aqualink RS Pump Delay Issue
    Apr 2016
    Austin / Texas
    4
    When I hit my Spa button my Pump doesn't turn off while the valves turn like it always done before. I verified in the System Setup Menu the the Pump Lockout is on. What else can I troubleshoot to fix this problem?
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Re: Jandy Aqualink RS Pump Delay Issue
    So it used to turn the pump off right away? Maybe it's shutting the pump off after a cool down period of say 10 minutes.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You can enable/disable the pump to run during the valve rotation, but the pump will run in a "cool down" if the heater has run in the 5 min prior to hitting the button to shut off.
    IOW, if you have the pump run during valve rotation disabled, and the heater hasn't run (5 min prior), the pump should shut down when you hit the (spa) button to turn off.
    menu-help/system setup/pump lockout/enable,disable.
    Factory Warranty Station for:
    Apr 2016
    Austin / Texas
    4
    Gentleman thanks for your replies.
    The pump has always turned off during valve rotation (pump turns off the pump light blinks while off usually 30 seconds or so) then after rotation it turns back on.
    I have the pump lockout on in the system setup and haven't had the heater on in days and it's still not turning off during valve rotation.
    I have tried Clearing Memory, should I try the reset button on the side of the Control Panel?
    Any other suggestion or ideas on what the problem is?
    I guess the downfall to it not working again would be the strain on the valves during rotation to cause them to go out faster...
    Apr 2016
    Austin / Texas
    4
    Update, I needed to shut the power to the pool equipment at the main breaker the other day. When I used the Spa last night the pump did delay during valve rotation.
    Not a issue anymore!
