Thread: Partial LED disply
    Jun 2014
    Virginia Beach, Va
    23
    Partial LED disply
    Aqua-Trol SWG
    Led display is working, but only partially, the last 2 numbers are either faint/hard to read or missing a "black dash". I opened the panel and LED, pins & board look clean.
    Just downloaded the Diagnostic manual and it goes over steps to check for No LED display. If mine is a partial display would the checks for the transformer, rectifiers or DSP Boards be the same & could I tell the bad part ?
    what's a good place to order replacement ?
    thanks
    14,200 / AG / vinyl /Hayward S108T sand filter/Hayward 1hp sp pump /4 yr old pool / Taylor K-2006c / SWG AquaTrol RJ
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Partial LED disply
    I wish I could help. the only thing I can think of is calling hayward and asking where it can be repaired, they are usually pretty good at helping..
    Jun 2014
    Virginia Beach, Va
    23
    thanks -
    been busy last couple days - will troubleshoot using the manual and see what it says & if needed call.
    trying to do this as inexpensive as I can BUT already have to replace our kitchen stovetop because of the darn SWG. had it in the kitchen earlier (raining outside) to clean the inside & see if anything was burnt. when I went to take it back outside I didn't notice that the swg mounting flange was under the stove top. cracked & shattered the stovetop - i'll be installing the new one this week.
