Thread: Rubber piece at top of liner coming out
    I noticed today that there are rubber thin strips that go all the way around the pool right at the top of the liner. Im guessing this helps hold it in place. Well at certain spots this strip is coming out. What is a easy way to get these to set back in? Just pushing them didnt seem to make them stay to well. Thanks.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Rubber piece at top of liner coming out
    What type of liner do you have beaded, over lap?
    A pic would be helpful for us to advise you how to solve your issue .
    Also adding your pool specs to your signature will help others who try to offer advice. Type of pool. equipment etc ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Its a 16x32 inground with a beaded liner. A pool store mention it might be some loc n' roll coming out. But this looks slightly different then loc n' roll does.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Is the liner itself coming out of the track anywhere?
    nope
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Then that's probably just liner lock or something similar. If you have a rubber mallet handy that's probably the easiest way to tap it back in place.
