Results 1 to 7 of 7
Thread: Indentations in pool floor
    Apr 2016
    Blackshear, Georgia
    3
    I am in the middle of having a 16x32 inground pool installed and the pool floor was finished and liner layed in on Thursday and on Sunday while the water was filling up my daughter got in and was walking around the shallow end and several large indentations formed where she pushed off with her feet so I walked in and was able to push down and create indentations also...mostly along where the pool starts to slope into the deep end but also around the edges in the shallow I end. I have called our contractor who is to come back out today but wanted second opinions for when he gives me his cause for this and solution. I believe they did a poolkrete bottom. Thanks!
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Indentations in pool floor
    the soil underneath is going to compact as they fill the pool, if the indentations are still there after a few of water is in, then make them remove it and fix it. Do NOT accept poor craftsmanship, and dont be talked into accepting something you are not happy. you are the customer and paying a premium to a contractor to deliver what you paid for. Do NOT accept anything short of that, regardless of the belly aching and whining the contractor may do.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Apr 2016
    Blackshear, Georgia
    3
    So if he pulls the liner to fix this will the original liner be able to be used or should I expect a new liner..the main steps, light & skimmers have been cut out but no the returns or secondary ladder in deep end?
    Nov 2011
    Moberly,MO
    1,010
    Hate to say this but possibly you are at fault and not the builder. Did the builder tell you it was okay to be in the pool. If not then this is on you to do the fix , just depends on the builder. I tell my homeowners they can't get in until I give them the OK.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2016
    Blackshear, Georgia
    3
    The builder and crew were in the pool walking around an hour before cleaning and after three days of a liner being in and the pool halfway full I would think the bottom should have been hard enough to not leave footprints. Also, the builder did not give any instructions not to enter pool.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Footprints in the shallow end where people walk often may smooth out over time as others work the floor walking.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by swimcmp View Post
    So what are the circumstances that would make it OK or not, and what is a typical time on this?
    Essential Links:
