Thread: Pool skimmer slow drip
    Jun 2014
    NYC
    44
    Hello i have moved into a house two years ago they already had a pool set up i believe it was from 2007. I bought new filter last summer. The summer i moved in i bought a new hayward skimmer. I installed it put a beed of silacone outside of the pool around the skimmer as well.i noticed since switching the inner plate off to cover it for winterizing its been dripling around the bottom of the seal. What could be wrong? screws are loose seal is cracked. Silacone is bad? Whats a good sealant i can use. Any ideas would be great.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool skimmer slow drip
    Welcome, I think you are talking about an above ground pool, is this correct? If so, if the seal is cracked and the screws are loose and can not be tightened then I would recommend replacing the skimmer with a new one.. I used no silicone on my install and have no leaks at all, granted it is only 2 years old..
    If you could load some pictures we may be able to give you some more advise
    Jun 2014
    NYC
    44
    Ok thank you and sorry yes its for a 21ft above groud pool
