Results 1 to 7 of 7
Thread: Pump types
    Mar 2016
    Chicago,IL
    88
    Pump types
    Been doing a lot of research and possibly looking at getting a swg. Do they work with any style pump? I have cartridge pump and curious if I would have to change to go salt?
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    30,415
    Re: Pump types
    Do you mean you have a pump and a cartridge filter? If so, the SWG is indifferent to filter types....it makes no difference.
    Mar 2016
    Chicago,IL
    88
    Re: Pump types
    Yes thats what i was getting at. Wasn't sure if I had to have a specific style filter to use one.
    Is it more of a personal preference or is one method preferred over the other(salt/bleach)
    30,415
    Re: Pump types
    They each offer differing benefits.
    Bleach is generally the least expensive and the best form of chlorine you can use but probably the least convenient.
    An SWG is perhaps the most convenient but has quite a bit more upfront cost.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: Pump types
    SWG will work with any filter. More here on different chlorine options, Pool School - How to Chlorinate Your Pool
    Jun 2011
    Long Beach, CA
    2,781
    Re: Pump types
    Quote Originally Posted by pooldv View Post
    Almost any filter, I've seen some older stainless filters that developed pin sized holes that leaked water. The newer filters are all plastic based and are fine with SWG's.
    DFW, TX
    24,484
    Re: Pump types
    I'm not old enough to remember those!
