Thread: What salt to buy
    Oct 2015
    Katy/Texas
    411
    What salt to buy
    I can buy
    Diamond Crystal 40# Pool Salt (99%)for $6.45 a bag or
    Diamond Crystal 40# Salt Solar Crystals (99.6%) for $4.37 a bag.
    Besides $2 a bag, what is the difference.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Donldson's Avatar
    NW Ohio
    2,926
    Re: What salt to buy
    The pool salt will probably be crushed a bit smaller and dissolve faster. Either will work but the faster dissolve rate is not worth $2 a bag IMO.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    38,547
    I have only used solar salt in my pool, same stuff.
    Oct 2015
    Katy/Texas
    411
    I order a salt testing kit, after I test I'll buy the cheaper salt for the pool. I should be able to pick up a pump and SWG Monday at Discount Salt Pools. It's about a 30 minute drive from the house. The salt can dissolve while I procrastinate installing the new equipment.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    LOL! That is how I install equipment too. No comment on how long my heat pump has been sitting in the box!
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,156
    Just converted to a SWG and put 900 lbs of the cheaper solar salt and it dissolved in about 4 hours. I did brush it which seemed to speed up the process.
