Results 1 to 12 of 12
Thread: Pebble Tec
    Sep 2014
    Milton/ga
    22
    Pebble Tec
    We have installed pebbleTec recently. The installed surface looks like Caribbean Blue, but we selected Tahoe Blue. I mentioned this to our prime pool renovation contractor. They said that Pebble tec takes 90 days to cure and the color will change to look more like Tahoe Blue. I'm skeptical. Has anyone experienced pebble tec and the curing process affecting the color of the pebble tec over a period of 90 days making it darker in appearance? This is a close up of what was installed and acid washed on Saturday.
    http://www.pebbletec.com/browse-our-...es/pebble-tec/
    Unfortunately I think they made a mistake.
    Tracy -- 30,000 gallon in-ground gunite pool with above ground SPA (two fountains). Controller(s): Zodiac iAquaLink2.0 + Jandy AQPLM AquaPalm Salt Water Generator: Hayward AquaRite Salt Generator Complete 40,000 Gallons | Power Center and Salt Cell Kit | AQR15 Filter: Pentair FNS60 50 p.si., Model sm20-2, rated flow 125 GPM Cleaner: Polaris Heater: Pool Pump:SQ FL FR 2HP EE 230V Pentair Superflow Pump
    Aug 2014
    Houston tx
    2,524
    Re: Pebble Tec
    This is Caribbean Blue.
    Pebble Tec Pebble Tec
    An earthy assortment of golden and grey pebbles. This finish produces a medium blue color and is comparable to PebbleSheen Blue Granite.
    This is Tahoe Blue.
    Earthy golden and grey pebbles blended with dark brown stones. This finish produces a medium blue water color.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Aug 2014
    Houston tx
    2,524
    Re: Pebble Tec
    They are not the same, but i can see how they could get mixed up. The samples were off the PT website.
    Marla
    Sep 2015
    Hartford/CT
    194
    Re: Pebble Tec
    I have heard it takes a couple months for the color to settle in.. Same with plaster. Fingers crossed it comes out just as you planned. As spending all that money and it is wrong.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Pebble Tec
    Feel free to contact Pebbletec directly, they are very helpful and interested in resolving customer issues. The real question is if it is wrong, are you interested in having them chip out what you have and putting in a new finish? They will definitely do it, I have seen it many times. My PB and neighbor has told me quite a few stories about issues like that and Pebbletec's willingness and interest in making it right.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: Pebble Tec
    Are they really different?????? It is hard to see the difference!
    Kim
    Aug 2014
    Houston tx
    2,524
    Re: Pebble Tec
    Hmmm, maybe I copied the same one... I thought I originally saw a difference.
    Marla
    Feb 2011
    Petaluma, Ca
    665
    Re: Pebble Tec
    Look here new pool Petaluma Ca
    post #41 shows some close ups of my Tahoe blue pebble. I think yours looks the same.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Sep 2014
    Milton/ga
    22
    Re: Pebble Tec
    Quote Originally Posted by pooldv View Post
    That's my plan. It is definitely lighter than the sample.
    Your pebble Tec went in a lot darker than mine for sure. Hopefully we will see a change in 30 days. This is what it looks like now.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: Pebble Tec
    Mine took a few months to get where it is now. BUT I have heard of the wrong color being put in by accident too.
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    Sep 2014
    Milton/ga
    22
    Re: Pebble Tec
    Here is another pic as we fill the pool.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: Pebble Tec
    That attachment didn't come through
    ~Wendy
