Thread: Can't figure out why pump is still leaking.
    Feb 2014
    dfw tx
    67
    So i've changed out the pump shaft seal, the locking screw and the impeller. It still leaks from the top where the shaft seal goes. Changed out the shaft seal and it still leaks. Cleaned shaft itself and still nothing. Anything I can be missing?
    Thank you
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    Re: Can't figure out why pump is still leaking.
    Is it a Whisperflo?
    Support the site
    Feb 2014
    dfw tx
    67
    Quote Originally Posted by JamesW View Post
    Is it a Whisperflo?
    no challenger series
    16k gallons
    1hp pump
    Built in 2000
