Thread: Pentair Superflo VS
    Apr 2016
    Marlow, Oklahoma
    2
    Pentair Superflo VS
    I bought a Pentair Superflo VS last July. The pump ran and worked great until I closed the pool for the winter. I uncovered the pool a couple of days ago and filled it back up above the skimmer, when I went to turn the pump back on it wouldn't work. There is power to the pump, the pump and motor is not locked up. The indicator lights on the controls won't light up. They won't show the power on or even if it has a fault. Is this unit toast and if so how long is the warranty. I read where some is 2 months and some is 1 year. An help would be appreciated.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Pentair Superflo VS
    Welcome to TFP!
    First thing I would do is contact the store where you bought it to see what they say.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    Check the breaker? Anything else work on that outlet?
    Apr 2016
    Marlow, Oklahoma
    2
    I checked the leads to the pump, the correct power is to the pump, everything else that is coming out of that breaker box is also working.
    I also had planned on calling Pentair tomorrow, and maybe the store also. I was just hoping it would be something easy and someone would have an idea on what to do.
    Jan 2012
    340
    Unfortunately those drives are not serviceable. If you have correct voltage to the pump and the drive is not lighting up, it needs to be replaced. Hopefully you are still under warranty and they send you the whole power end.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
