Results 1 to 8 of 8
Thread: SoCal Noob
    Kdfoust's Avatar
    Feb 2016
    Riverside, CA
    10
    SoCal Noob
    Hi There!
    Back in January I closed on a house with a pool. It's a 27k gallon lazy-L built in 1968. There's a spa on the side of the pool and we have been enjoying that almost nightly. The pool temp is coming over the mid 70s with the addition of a solar cover and it's swimming season here!
    When we were in escrow on this house I was talking to a friend about the pool situation, I've never had one, and he said a pool is no more trouble than having a cat. I thought, "oh no, I'll never get that under control" (I've never had a cat).
    I'm glad to have found this forum as the folks at the pool store really annoyed me; always up-selling, blah, blah, blah. I had also intended to have a pool service "take care of cat" for awhile as I had other things to do. I found the serve to be annoying at best and expensive at worst. I fired them and decided to just start maintaining the pool myself.
    Things were going well until...some recent family emergencies took me away from the cat and with the pool temp increasing dramatically, I had a algae bloom! Based on what I'd already learned here I put down almost immediately following the SLAM procedure.
    It's funny, people have a lot of weird ideas about pool chemistry; I'm glad I found this forum. I'm an engineer, but don't hold it against me.
    Regards,
    Kevin
    27000 gallon lazy L, with attached spa, DE filter, Heater, variable speed pump. I do it all, no pool fools on my property!
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: SoCal Noob
    Welcome! I'm in Riverside too.
    What kind of Engineer?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: SoCal Noob
    Welcome to TFP! Congrats on the new. Pools are quite a bit easier to take care of than cats. And we have pretty good cats.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: SoCal Noob
    Quote Originally Posted by pooldv View Post
    My mental picture of you has changed
    -Brian-
    POOL BUILD
    DFW, TX
    24,514
    Re: SoCal Noob
    LOL!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: SoCal Noob
    Welcome, Kevin!
    Your friend is actually right. What does a cat really need? Daily feeding; bleach. Keep the water full. Vacuum up the hair, clean the litter box; vacuum, clean the skimmer. Dead mouse in the skimmer; dead mouse on the doorstep. Similar duties, similar time demands. But you won't get torn to shreds when you take the pool's temperature.
    Kdfoust's Avatar
    Feb 2016
    Riverside, CA
    10
    Re: SoCal Noob
    Quote Originally Posted by bdavis466 View Post
    Automation. Mechanical process development and factory automation. I build process automation systems that connect technology with business needs. Nowadays I'm doing a lot of vision guided robotics replacing mechanical feeder system with flexible feeder systems.
    The pool is fun for me. I remember one useful thing, and only one, from chemistry back in the day: for every 10 C increase in temperature, reaction rates double. That's it; it's all I've got for Chem!
    Regards,
    Kevin
    Casey's Avatar
    SW PA
    10,461
    Re: SoCal Noob
    Welcome to TFP! We wont sell you anything unnecessary but you should make sure you have a tf100 test kit.
