Results 1 to 20 of 20
Thread: Pool filter help
    Apr 2016
    Larue,Tx
    16
    Pool filter help
    Ok guys I need help. I have had this pool this being the 3rd season. 1st season the pool went great. No algae stayed clean and well it was great. 2nd season was where it got bad. mid season the pool kept getting green. All the chemistry was fine but it just kept doing it no mater what I did. The only thing I could do is when it got real bad just drain clean and refill. This way is costing me an arm and a leg and I am running out of limbs to give up. This season I went to a pool store and talked to them all to find out when I bought the pool I didnt put the proper amount of Zeo sand in. The seller of the pool told me that I just needed enough Zeo Sand to fill half the filter up. With that being said I have yet to open the pool back up because I have to drain it and do a deep clean on it. Then get new sand to fill the filter back up.
    With this being said here comes the questions.
    1st What kind of acid should I use to do a deep clean on the vinyl liner?
    2nd I just bought a Quad D.E filter so can I use this filter behind the other or can I only use one filter at a time?(My way of thinking on this is to Use regular pool sand in the sand filter to pull out the microns down to 10 and with the Quad D.E. pulling the rest out and make it cleaner.)
    Please help.
    I have a 21' above ground pool (11,700 GAL) with a Zanzibar 54" unibead liner. I am running a Pentair Intelliflo 2 VST with a Sta-Rite Crystal-Flo IIhigh rate sand filter with a Hayward AquarRite 900 SCG and a Pentair Rainbow 320 automatic chlorine in-line feeder(for winter)I am running everything off a Pentair Easttouch 8 control system.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool filter help
    You have a chemistry problem not a filter problem.
    What are you using as a sanitizer? Trichlor pucks?
    Read this:
    I also strongly suggest you buy one of the recommended test kits either the K2006 or the TF 100 and you start testing your water yourself.
    A DE filter will not solve your problem. Your water has insufficient active chlorine.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Only one filter is needed, either one is fine. Algae is not cured by filtering it is cured by proper water chemistry. How do you chlorinate your pool? If you are using trichlor pucks then the most likely reason you got algae was high CYA/stabilizer and lack of chlorine to compensate for the high CYA.
    Have a read here and come back with questions, Pool School - ABCs of Pool Water Chemistry
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,455
    Chris,
    The best help I can give you is to "Stay Out of the Pool Store". Their job is to sell you stuff and they appear to be pretty good at it.
    Honestly, the first thing I did after reading your post was to double check to make sure it was not posted on April 1st..
    It is impossible for the "chemistry to be fine" and still get a green pool. I'd hold off installing the new filter, as you way want to return it.
    If you follow the advice that you will get here, these guys will soon get you back on track.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    I have no experience with vinyl pools, so I can't help with that much. However, muriatic acid will only work if the problem is Calcium scale. That will be like home-grown sandpaper. If the stains are blotchy they may be metal. If you're filling from a well or if the pool store sold you a mineral system (poolfrog, Nature2) then that's a possibility. Ascorbic acid cleans that. If the stains are organic then time and proper chlorine levels will remove them.
    This scenario I wrote up a couple years ago may help you understand why you got algae.
    We'll take a 16000 gallon pool, because that's what I have. On a fresh fill, prominent national pool chain recommends 2.5 pounds pf stabilizer per 10,000 gallons, which works out nicely to 4 pounds which brings CYA to 30.
    With an average loss of 2 PPM/Day or 14 ppm/week, I'll have added 8.6 PPM/CYA if I used trichlor pucks perfectly. And they recommend a weekly "shock" of dichlor between 5 and 10 FC.... 2-3 oz per 10,000 gallons. Split the difference; I'll add 4 oz. CYA went up another .9.
    So..by the end of week one, I have added 9.5 more CYA. It is now 39.5. Mimimum FC for that is 3, so I'm probably okay.
    Week two, up to 49 CYA.
    Week three, 58.5. Minimum FC should be 5, but they recommend 3 as ideal, so the pool looks a bit hazy. So I'll toss in a little extra dichlor "shock" to jack FC up to 10. Which adds another 6.4 CYA. Keeping count? We're up to 64.9 now.
    That caught the algae just in time.. we had two weeks of good luck. A steady diet of pucks and 4 oz. "shock" each week only added another 19, up to 73.9 now.
    Week 6 it started looking funky, so we "shocked"it once again. CYA is up to 99.3. But minimum FC to keep algae at bay is 8, and we're still holding things to 3, because prominent national chain's preprinted sheet shows that as ideal. So algae got a toehold and the pool has a bit of a tint. So we throw two whole bags of dichlor in which jacks it another 7.6 by the time week 7 is over, we're at 116.4, because we had pucks in the floater the whole time.
    So...in 7 weeks, from 30 to 116.4. Let's say there are no more algae outbreaks because they sold me a huge bucket of phos-free and another of yellow-out monopersulfate "shock" Nothing but the pucks and the extra 4 oz of dichlor "shock" weekly. So the next 7 weeks added 66.5, which brings the total to 182.9 CYA.
    Now if we didn't understand this and things looked a bit hazy, we might throw an extra puck or two in the floater every couple weeks, which will drive it over 200 easily.
    Apr 2016
    Larue,Tx
    16
    ok so what yall are saying is that even though I only had the filter filled halfway with sand that will still not cause the water to not get cleaned.
    Also I am using tabs with 2 floating puck holders that I keep full. The chlorine levels stay a little high yes but that is why Im confused as to why I am growing so much algae in the pool. With that much chlorine im not understanding why the algae.
    30,402
    Not really. Regardless of the sand level, a filter will not filter live algae from a pool. You have a chemistry problem......not filtration.
    How much chlorine do you have?
    Apr 2016
    Larue,Tx
    16
    I kept the chlorine level at around 5 to 6
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,392
    You are correct............it is NOT a filter problem. It IS a water balance issue as in there is not enough Free Chlorine (FC), maybe to much CYA (stabilizer), PH and TA may also be off.
    If you get your own test kit we will be able to help you get your water balanced AND looking like a jewel. It will be cheaper in the long run as well!
    Look in my siggy for the test kit I think is the best bang for the buck.
    Kim
    Just saw that you have two floaters full of tablets............I am willing to bet your CYA is sky high. The higher the CYA the more FC you will need. After a while you will not be able to put enough FC in due to the CYA being so high.
    DFW, TX
    24,450
    Chlorine level is set based on your CYA level and this chart, Chlorine CYA Chart. My CYA is 70 right now and I keep my FC at 8-9 ppm.
    Apr 2016
    Larue,Tx
    16
    see my home test kit only has fc, ph, alk, and stabilizer,
    i do remember the last time i checked everything before i closed it for the winter I was ph 6.8 fc 5.5 alk 80 and sta 65. these numbers were aprox due to me having a cheap digital test kit.
    DFW, TX
    24,450
    Ahaa, you need a TF-100 from TFTestkits.net
    Apr 2016
    Larue,Tx
    16
    ok guys i have redone my pool. drained cleaned and put a new filter on the pool. When I got it filled the pool filled I went ahead and tested the water. The results are as follows.
    TC 0
    FC 0
    CC 0
    PH 7.5
    TA 120
    CH 40
    CYA -30 (My tube only goes up to 30 and the dot was still there all the way up to the top)
    After I Dumped shock in and cranked my chlorine up to 5 and ran the pool for 3 hrs I checked it again. It now reads as follows.
    TC 5( my test only goes up to 5)
    FC 5
    CC 0
    PH 7.8
    TA 120
    CH 30
    CYA -30(same reason)
    Please I need help.
    DFW, TX
    24,450
    What do you need help with? How does your water look?
    What color is your chlorine test? Yellow? That is OTO and as the shades get more yellow it indicates higher chlorine level, like tweety bird yellow, school bus yellow, light orange, orange julius.
    CYA, is the water clear or cloudy? Clear is 0 and cloudy is 10-20.
    PH is OK, just lower it to 7.6 when it gets above 7.8
    TA is OK
    CH is not important in a vinyl pool as long as it is below 500ish
    Read here, Pool School - ABCs of Pool Water Chemistry
    Apr 2016
    Larue,Tx
    16
    Water is cloudy enough I cant see the bottom of the pool but the CYA is not indicating that. the chlorine test is pink. very light to almost no pink for 0 and dark pink for 5. I tested the water again today and the pool is still cloudy.
    TC 5
    FC 5
    CC 0
    PH 7.5
    TA 90
    CH 30
    I didnt test the CYA because of the last results indicate that the Cya if great.
    DFW, TX
    24,450
    Cloudy pool water is rarely (never) a filter problem. It is nearly always a water chemistry problem. If your water is cloudy then you most likely need to follow this process, Pool School - SLAM - Shock Level And Maintain
    You will need an FAS/DPD chlorine test like this one, FAS-DPD test TFTestkits.net
    You can Perform the Overnight FC Loss Test (OCLT) to verify if a SLAM is needed. But, again you need the FAS-DPD chlorine test for precise chlorine measurement.
    Apr 2016
    Larue,Tx
    16
    Quote Originally Posted by pooldv View Post
    I know its not a filter problem seeing that this is a brand new fresh filter.
    I have a fas-dpd test kit.
    DFW, TX
    24,450
    Quote Originally Posted by chrismachowski02 View Post
    Good, then you can tell us what your FC level is exactly and what your CC level is. How many drops does it take to clear the sample?
    Apr 2016
    Larue,Tx
    16
    The test kit does not have me do that but it does say fas-dpd on the box.
  20. Back To Top    #20
    Apr 2016
    Larue,Tx
    16
    OK so I was wrong. It is just a DPD kit. I picked up the wrong one. I will be getting a fas DPD chlorine only kit Friday.
