Results 1 to 9 of 9
Thread: Hot tub went from blue to green in 30 minutes - could it be icing?
    Oct 2015
    Austin, TX
    83
    Hi,
    Just had a birthday party for my 7 year old. We had about a dozen 7-year-olds in and out of the hot tub and between the hot tub and the pool for the last 2 hours.
    I changed the water in the tub 2 weeks ago and installed a new filter at that time. Started off with Brom Bank that I shocked appropriately. Since then the bromine level has been kept up in the 6-10 region by floater with bromine tabs. I balanced everything this morning and cleaned the filter
    - Bromine about 10 (in anticipation of bather load),
    - Combined Bromine about 4 (not sure why),
    - TA 70,
    - CH was 50, but I added enough calcium to take it to 110.
    - PH 7.5,
    - borates about 20.
    After about 90 minutes of kids in the hot tub, I tested the bromine and it was down to about 1, so I kicked all the kids out and added 1/3 cup of 10% chlorinating liquid. After that, I noticed the hot tub take on a green hue. I hit it with some more chlorinating liquid, and it just got worse.
    I'm thinking one of the kids had some icing on them and that it's icing that is dyeing the water green.
    Any other reasonable explanation?
    Marc
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Donldson's Avatar
    NW Ohio
    2,896
    Re: Hot tub went from blue to green in 30 minutes - could it be icing?
    Is this a clear green or cloudy green?
    Have you used any mineral system or algaecide in the tub?
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    That would have to be a whole lot of icing to turn the water green. Did any of the products you use have copper in them?
    Love TFP? Become a
    TFP Supporter!
    Apr 2013
    Sacramento, CA
    2,769
    Are you on city water or well water? Have you had your water tested for metals?
    Oct 2015
    Austin, TX
    83
    @Donaldson, it's a clear green. No mineral system nor algaecide - just bromine bank (to start), bromine tabs, bleach (to oxidize), dry acid, baking soda, and borax.
    @zea3, I haven't added any copper, but I don't think any of the kids would have had any on them. There was a LOT of food coloring in the icing...
    @gwegan, City water. Haven't had it tested but I haven't had the problem before.
    Thanks all!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I don't think there's any chance 500+ gallons of water takes on that noticeable a color change from someone transferring in some cake icing with food color.
    Any chance one of the kids had a brand new green swim suit ?? If it was never washed and cheaply dyed it might be able to bleed off enough color in the hot chlorinated water.
    Solar Blanket, Well Water, Borax Added. 68
    Oct 2015
    Austin, TX
    83
    Well, I dumped so much bleach in it that the OTO test in my TF-100 was orange... the next morning the green hue was gone. So whatever it was, I guess I got it...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by marcgr View Post
    That's the way to do it.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
