Results 1 to 8 of 8
Thread: What's the best order to convert to SWG?
    Mar 2016
    Collinsville/OK
    4
    Hi! Last summer we installed an Intex 22'x52" ultra frame pool. We kept it going with Leslie's pool store products, I have since discovered TFP and pool school. I have been reading on here like crazy. I ordered and have the tf100 testing kit, along with the stirrer. We have also purchased an Intex SWG and Intex sand filter, but have not installed them yet. We opened the pool today, cleaned it out and just hooked up the Intex cartridge filter(2500gph) until we figure all this out. We used an Aquapill over the winter.
    Here are my test results
    FC .5
    CC 0
    PH 6.8
    CYA 80
    TA 60
    CH 100
    What should my next step be? Do I add bleach to raise my FC? Start adding salt and hook up the new Sand filter and SWG?
    I am so thankful to have found this wonderful forum with such great info and helpful people.
    Intex 22'x52" ultra frame(~10,000gal) with Intex sand filter pump with 3000gph filter.
    Intex deluxe skimmer. Set up Aug 2015
    Testing with TF-100 and mag stirrer
    38,235
    Re: What's the best order to convert to SWG?
    Welcome to TFP!
    Was this a fresh fill or do you have some algae in the water?
    Yes you should raise the FC with bleach, how much depends on whether you need to SLAM first.
    The pH should be raised into the 7s as well.
    Have you played with PoolMath?
    Mar 2016
    Collinsville/OK
    4
    Jbizzlw- Thank- you for responding We filled it last August when we set it up. We topped it off today. I don't see any algae, the water was pretty clear when we took the cover off, but now that we have stirred things up its a bit cloudy. I haven't played with the pool math yet.
    JoyfulNoise's Avatar
    May 2015
    13,170
    The first order of business is to get the pH up to 7.2 (use borax or soda ash....i'd use borax). Then you need to SLAM the pool. However, your CYA is high (great level for an SWG but a bit too high for manual chlorination) so that means you'll need a fairly high FC to bring it to shock level.
    Your call - you can either shock at the higher FC or drain and replace 50% of your water to make the CYA 40ppm and then shock at the lower FC value. Then, when you finally concert to an SWG, you can raise the CYA back up again.
    Matt
    38,235
    I would suggest it will be cheaper to SLAM with the higher CYA, than to drain, fill, add more CYA and salt.
    May 2015
    13,170
    Yeah, I should have added that it all depends on your source of water. 5,000 gallons of water for me (desert dweller) ain't cheap. If you have high municipal water rates, then SLAMing at high CYA is cheaper. If your water is cheap, or from a well, maybe draining to get a lower CYA is cheaper.
    Either way works, just go with whatever is cheapest and the least hassle.
    Matt
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome, So glad you found us
    Hook up your SWG and new pump/filter, just dont turn on your SWG yet, you will start that up once everything is good
    Good old 20 Mule Team Borax will bring your PH up, 7.2 will be great (your low TA and PH is great for a SWG)You can take your
    fc to SLAM level (24 for CYA 70) with regular bleach (atwoods has 10% liquid pool shock for 10 bucks for 4 gallons, great price) and keep it there for a couple days and then do an OCLT and see if you pass all 3 tests.. If you do pass let it drift down to FC of 6
    you can add your salt now (remember test you water first to see what salt level your at) and then when you fc gets back down to 6 fire up the SWG..
    It will take a couple weeks to dial in your pump and SWG time to keep you FC at 6.. try starting out at 6 hours a day and see what that gets you
    Hope this helps
    check out my links below, poolmath is great
    Mar 2016
    Collinsville/OK
    4
    Thank you so much! We have a plan now! We had Soda ash from last year so we just used the pool math calc to add the right amount to raise the Ph. We are headed out to Attwoods, thanks again.
