Thread: Liquid Chlorine
    Jun 2008
    Is there a way to tell what percent liquid chlorine is? The pool store (which I hate to buy from) has nothing but high school kids working there and when I ask what % it is I got an answer of 47%. . Needless to say no one ever gave me the correct answer so I am wanting to test it myself. Also is $6 for 2.5 gals high for liquid chlorine. I know it probably depends on the strength. I am paying $2.54 for 1.3 gals of 6% now. Thanks for your help
    24' AG, 52" wall ,resin with 1Hp pentair pump with sand dollar sand filter. Hayward aquatrol salt generator
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    Re: Liquid Chlorine
    I buy it at 12.5% from the pool store. Its a bit more concentrated is all. $6 for that concentration is high. I paid $5 for mine this year at that concentration and that is why I buy it. Its a bit more concentrated for just about the same price. Basically it still does the same thing, its just a higher dose is all.
    Hope that helps.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool:
    Jan 2009
    Cupertino, CA
    Re: Liquid Chlorine
    It ought to be labeled, if you can look at the package yourself.
    $6 for 2.5 gal where I am is cheap for 6%, very cheap for 10%.
    $2.54 for 1.3 gal of 6% is between those two. So, assuming the pool store's chlorine is 10%, you're better off buying it there.
    BBB "Intermediate Swimmer"
    Re: Liquid Chlorine
    Easy way to tell the strength is to add 1 gal per 10k gal of pool water. It will raise the FC by approx the strength of the chlorine. So if you have a 20k gal pool you want to add 2 gal, Test the water before adding and after and subtract the first test results from the second and you will have the approx chlorine strength!
    coastal's Avatar
    Apr 2009
    Stuck In Paradise
    Re: Liquid Chlorine
    The % is on th label.
    I pay $4.38 for 2.5 gal of 10.5% so it would not be a savings for me to buy the 6% clorox at Walmart.
    30x18 inground plaster/pebble with spa
    Hayward cartridge filter C751 1.5 hp pump
    In line tablet chlorinator
    Heat pump heater
    Aqua Logic wireless controls
