Thread: Muriatic Acid concentration
    Apr 2015
    David City, Rep. of Panama
    15
    Hi all,
    I have a question regarding muriatic acid concentration. I can only get the product with 10% concentration, and I would like to add my borax.
    Since the Borate section in the Pool Math calls for 31.45% (20 Baumé) concentration of MA, I wonder if I would then need 3x the amount of MA since I can olny get 10% concentration (no degree baumé listed on the 1-gallon jugs.. only %).
    Thanks in advance for the advise !!!
    Reinforced concrete 10m x 3.5m x 1.50m rectangular pool (fill volume = 44.67 m3 - approx. 11,800 gallons), partially in-ground (about 50%), Pentair Whisperflo (WF-23) 0.75 HP, Pentair SD-60 Sand Filter, and one Pentair Intellibrite 5G white LED light, tile covered walls & bottom, Taylor 2006-C & TF-100 test kits.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Muriatic Acid concentration
    Yes.
    Slightly more than 3X the acid .... 3.145X to be precise.
    Apr 2015
    15
    Thank you so much !!! all clear then for the borax...
