Results 1 to 8 of 8
Thread: Hayward Prologic/AQUAPLUS frimware update
    Apr 2016
    Oakdale,ca
    8
    So I have a Hayward prologic/aquaplus system and I purchased the Aqua Connect Module for the house so that I may use the Hayward app from my phone to control my pool system. Well now I realize that the firmware or version of my prologic/aqualogic is older than required.... Is there anyway to update the prologic/aqualogic system or version??
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Hayward Prologic/AQUAPLUS frimware update
    You have to replace the main board to upgrade. $$
    BTW, welcome to the forum.
    Mark
    Apr 2016
    Oakdale,ca
    8
    Ok I have board that's bad "the whole solder joint issue" part # 06608g-1 I am in need of a new board but with firmware compatible with the aqua connect module to allow me to control automation from phone/internet this required a version 4.20 or higher what do I need, can't seem to find a board replacement with that firmare....
    Any suggestions
    mas985's Avatar
    Pleasanton, CA
    11,737
    You can sometimes find them on eBay but you will usually have to ask for the rev number because they normally don't post it on the listing.
    Mark
    Apr 2016
    Oakdale,ca
    8
    Awesome thank you for the help
    Apr 2016
    Oakdale,ca
    8
    Thought I read it's possible somewhere but do you know if I can replace my board (GLX-PCP-MAIN Rev G) with (GLX-PCP-PRO)? Thought somewhere said it was compatible and had the newer version firmware to support the aqua connect
    mas985's Avatar
    Pleasanton, CA
    11,737
    The best thing to do is to call Hayward/Goldline tech support. They are fairly helpful when it comes to board versions, capabilities and compatibility.
    Mark
    Apr 2016
    Oakdale,ca
    8
    Awesome called Hayward and it is correct the prologic board is interchangeable with the aqualogic so now I can use the aquaconnect interface (iPhone app) as well as upgrade to variable speed pumps if I wish.. Thanks for the help!
