Results 1 to 7 of 7
Thread: Spa seems only to heat when jets are on
    Apr 2016
    Maryville Tn
    5
    I replaced the heater last year. Worked fine till late fall. Wouldn't heat so i replaced the temperature and Hi limit sensors. Now it seems to only heat when the jets are on. Please help me if you can.
    D2000 Dynasty Spa
    Balboa heater and circuit board
    Apr 2016
    Maryville Tn
    5
    Re: Spa seems only to heat when jets are on
    Replaced the filter too
    D2000 Dynasty Spa
    Apr 2016
    Maryville Tn
    5
    D2000 Dynasty Spa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    I'm not sure I understand. The pump has to be running for the heater to have water flow to heat. Are there 2 pumps?
    Apr 2016
    Maryville Tn
    5
    Well the spa should be heating while circulating (low speed) However it only heats when the jests are on. (High speed)
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Homilist View Post
    It sounds like a problem with the pressure sensor. Does the heater have an error on the readout when this happens?
    Mark
    Apr 2016
    Maryville Tn
    5
    Replaced the sensors and the pressure switch. When i replaced the pressure switch it seemed to fix the problem. Then had to replace a cracked piece on the pump housing. Then the problem with the heat returned. No error messages.
