Results 1 to 8 of 8
Thread: Trying again
    May 2015
    Winterville, NC
    6
    Trying again
    Hello everyone. Im going to start opening my pool this week. It went all winter without a cover so its green right now. Ive taken the Nature II Mineral sanitizer off and replaced with the Hasa pool liquidator. Ive also purchashed a Aquabot pool rover S2-40i to help with cleaning.
    To start, should I replace the sand in my filter? The current sand has went through about 3 seasons.
    I know there is debris on the bottom of the pool(leaves), should I vacuum these out before putting more water in pool(I drained pool before last winter just down to the bottom of the skimmer)? Thanks for any help yall give.
    27' AG Vogue pool with vinyl liner and metal shell 18,500 gallons 4 ft deep
    1.5 hp Pentair pump
    Pentair Sand Dollar High Rate Sand Filter
    Hasa pool liquidator with 3/8" upgrade
    TF 100 test kit w/ Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Trying again
    The sand in your filter was a million years old when it went in. A couple years inside the filter didn't wear it out. Leave it alone. Perhaps after you're finished with the initial cleanup and the water is clear you can try Deep Cleaning a Sand Filter
    The more organic debris you can remove from the pool, the faster it will clear. I'd start with a leaf rake so you don't clog up the plumbing with a wad of waterlogged compost. Then vacuum to waste if you can get the vacuum to work with the low water level. Sometimes the pump won't prime. Some people have had success doing a siphon vacuum. Set the vacuum head on the floor, carefully feed the hose in so all the air is pushed out, then cap the end with your hand and haul it out and over the side as fast as you can so it starts siphoning. Then vacuum.
    Once the big stuff is out, fill it up, get the water circulating, and when it's all mixed, test everything and get ready to SLAM. You could sneak some bleach in while you're filling and mixing, but don't go above 10 FC or you won't get an accurate pH reading. On second thought, you might want to test the CYA level before you start refilling because at least some of the Nature2 systems also use trichlor in the tab feeder. If it's way high, you might want to lose a little more water before refilling.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Trying again
    Good job switching over to the liquidator! That is going to be nice! Have fun scooping leaves!
    Aug 2015
    Folsom Prison, CA
    124
    Re: Trying again
    If you don't mind spending a few bucks, you can find some battery operated leaf rakes that attach to a regular pole and have a propeller which sucks all the leaves in a big bag. My pool had a whole fall season worth of leaves in it and I was able to get them all out in around a half hour. They are a little spendy, mine was $100 but with the amount of trees within fall range of my pool, if it lasts me a couple years I will think it is well worth the money.
    30,432
    Re: Trying again
    Quote Originally Posted by censored View Post
    Can you help us find a link to this product?
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Trying again
    https://www.pinchapenny.com/product/...attery-powered
    http://www.lesliespool.com/water-tec...aner/58038.htm
    **I haven't used either of those. This is only what I found through a google search.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    30,432
    Re: Trying again
    Interesting. I would question it's ability to handle a heavy load. Looks like leaves may get hung up in the propeller (Thanks, northrn)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Trying again
    Make one with a sealed rechargeable battery and I'm in!
