Thread: Super chlorinating when opening this year
    Dec 2015
    Newington, Connecticut
    113
    Ive read through the sticky on opening the pool (very helpful information, thank you). Since its my first opening and first time using the t 100 test kit should I be testing the CYA levels prior to super chlorinating/ shocking the pool. I pulled the cover back yesterday and circulated the water adding some pool shock and raised the ph due to the amount of rain we have gotten.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Super chlorinating when opening this year
    Yes, you need to test the CYA, that is what you will be using to set your FC level
    Jun 2014
    15,159
    Andrew, something else you might want to consider is posting a pull set of the most current test results. Sometimes we get a little nervous when someone mentions they "shocked the pool and increased pH". pH is usually something we need to bring down in most pools, and shocking ... well .... as Casey said we manage FC based on your current CYA level. They go together.
    So if you need additional help, or would like to post all the test results, feel free to do so and we'll give you a 2nd opinion. Have a great day.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Nice job on having the best test kit! Well done!
    You should test all of your levels before you do anything with the water. If you have any questions once you do your test share your numbers here and we can help you out.
    Kim
    Dec 2015
    113
    Thanks for all the replies,very helpful. My liquid shock addition was just to raise the fc levels a little bit to hold the pool over till opening. Temps are in the 40_50 range with cold over night temps. Probably two weeks till opening. I will have full tests results when the cover comes off. Last year I was using chlorine packs and had to raise ph through out the summer especially after heavy rains. This year no more packs just bleach/ liquid shock. Look forward to the changes. Thanks for all the help.
    Jul 2012
    Tallahassee, FL
    30,535
    Sounds like a good plan! I will be on the look out for your numbers!
    Kim
