Thread: Jandy Pool and spa lights out of sync
    Oct 2007
    Parkland, FL
    752
    Hello,
    I haven't used my spa at night in probably 5 months and tonight I noticed the spa light only seems to be changing to around 2 colors while the pool lights are doing all the colors normally. They are Jandy lights connected to a Jandy PDA system. They are all wired together and used to work fine. I see the spa light flashing red at times but it never stays at that, just deep blue and lighter blue. Is there a way to resync these or is my spa light dead?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Jandy Pool and spa lights out of sync
    Bump!
    Apr 2013
    Sacramento, CA
    2,769
    Try what they suggest here:
    Jandy watercolors LED lights won't cycle through colors
    Though I'm not convinced that will solve your problem.
    Jun 2015
    Charlotte, NC.
    82
    Because of the way those lights work, change them to a different color, then change them back to whatever you want. That should re-sync them I believe
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    Oct 2007
    Parkland, FL
    752
    Yes I
    Wow. That worked well for a reply. Anyway. I've tried cycling and resetting so it looks like the light engine that should last year's is dead. I hate jandy products.
