Thread: Countpyro1 Re: Need to replace pump timer
    Mar 2016
    Chicago,IL
    88
    Don't want to hijack but the timers mentioned(t-101m). Can these be used in a 15amp twist lock application. They only have a 3' cord on my pump so while staying to code but not sure how this could be applied. Would I add an accessible box and put this in series with the circuit?
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Countpyro1 Re: Need to replace pump timer
    Electrically, there's no problem with running the output wires from the timer to another box with a twist-lock receptacle. I don't know if it's up to code or not, but the timer is nothing more than a complicated on-off switch.
    Mar 2016
    Chicago,IL
    88
    Thanks for the reply. I am gonna have to talk to the local inspector and see what he thinks. From my understanding they are only requiring a shut off close by with a spa/hot tub. If they are also requiring with a pool I read
    some have used this as an alternative. Kill 2 birds with one stone. Does anyone have a recommendation on which timer to use. I have a 1.5hp 2 speed Malibu pump. There is a low/high speed but it's a switch on the side of the pump. Im
    assuming I'll run it on low to save money of I've done my research right?
    Mar 2016
    Chicago,IL
    88
    Got my 101 today and can't wait to wire it up things are coming together
