Results 1 to 16 of 16
Thread: Houston pool installer
    Apr 2016
    houston
    9
    Woo-hoo, first post!
    I'm currently getting bids from viking and trilogy pool installs, but want to look at leisure as well. Can anyone recommend a houston area installer?
    Thanks
    Mod note: He is looking at fiberglass pools just an FYI
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Houston pool installer
    Welcome, peruse around and check things out
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    I can't offer help, but welcome!
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Quote Originally Posted by river rat View Post
    Thanks
    Houston is big. If you are in NW you can PM me for builders.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    What Mark said - often builders from one area dont go to another area - the driving time is often not worth the hassle for them. I'm also guessing that good builders have sufficient business in their own areas.
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Aug 2014
    Houston tx
    2,524
    +1 on the above. I tried lots of PBs before I found one that built inside the loop. However, it seems you are looking at a vinyl pool so that might be different. I don't recall any Houston vinyl pool build threads.
    Oops I misread. You are looking at a fiberglass pool, right?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Apr 2016
    houston
    9
    Thanks everyone. We are in the lake houston area and mainly looking at fiberglass. So far I have install quotes from Aqua pools and American fiberglass. They were both within 2k of each other.
    Apr 2016
    houston
    9
    Anyone with a fiberglass pool have any guidance what to look for?
    Apr 2016
    houston
    9
    So we found a design made by Trilogy pools that we really like, supposedly its Latham pools top of the line product.
    Apr 2013
    Sacramento, CA
    2,769
    Generally Fiberglass pools have exclusive distributors with territories.
    So look up the website of the pool manufacturer whose design you like and that will give you your local distributor. So for Trilogy your dealer is (assuming Harris County):
    Aquamarine Pools of Houston
    25730 1-45 N.
    Spring, TX 77386
    United States
    phone: (800) 432-8994
    fax: (281) 203-5114
    mark@aquapools.com, donnaaquamarine@aol.com
    The Aqua Group Fiberglass Pools Spas - Austin, Dallas, Houston, and Surrounding Areas in Texas!
    Once you get some bids for pools you like post them on here and we can critique them. PM me and I can find some fiberglass folks to do that for you.
    Apr 2016
    houston
    9
    Here's what I got from aquapools.com
    Trilogy
    Nebula: $34,977
    Electrical allowance : $1500
    Gas heater: $2100
    Gas allowence: $1100
    Salt system: $1500
    Tax: $2470
    Grand Total: $43,647
    Natalieewall's Avatar
    Jul 2016
    Frisco tx
    15
    Hi! I am looking at the same model and same builder, did you decide to go through with the nebula? Just curious, I'm in the very beginning stages here
    Apr 2016
    houston
    9
    We ended up going with leisure pools and are very happy, I'll post up some pics this weekend.
    Jul 2016
    Frisco tx
    15
    Great! Can't wait to see!
    Apr 2016
    houston
    9
    Here ya go. Still working on getting the landscaping finished.
    Jul 2016
    Frisco tx
    15
    Love it! Love the color especially.
