Thread: Is salt level change an OK way to guestimate pool capacity?
    Oct 2014
    DFW Texas
    78
    Ive tried the calculator for size and average depth but That ia jsut a WAG... Since I am converting to salt, I though, "hey, I can figure out how much water I have.
    I was at 400 ppm salt and then I added 520lbs of salt (13 bags)
    I am now at 2800 ppm
    using the pool calculator by putting in 400 > 2800 and adjusting the gallons of water, The required salt hits 520 lbs at about 25000 gal...
    How accurate do you think that is? I had actually been estimating 25k gallons using the length/width /av depth method so I have to believe it is pretty close...
    haha, the guy at the pool store did some napkin math and said I have a 34,000 gal pool... which would be nuts.
    Looks like I need another 120 lbs of salt to get to 3400 ppm.
    7-10 year old In ground 20,000 gal, Aquabright ecofinish W/ Spa, waterfall and infinity jet, 60 sq foot DE filter, Single speed pump, Racer cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Is salt level change an OK way to guestimate pool capacity?
    Chemical additions are the best way to determine pool volume, especially salt since you're adding alot and it's 100% salt, and once it's in the pool, it's not going anywhere else.
    Isolated Spa - 345 Gallons
