Pentair ultra performance heat pump
Nov 9, 2015
79
Lawrence, KS
Our new pool is finally completed. We have installed the Pentair ultra performance heat pump, 125,000BTU. We are anxious to turn on the heat pump and I was curious what to expect. Our pool is 27,000 gallons and the average temperature right now in Kansas is about 65 to 70 during the day. We do have an automatic cover so that should help. We just filled with hose water and I'm curious to see how long until I can reach 80°. Any feedback is greatly appreciated
From what I read the pool heat pumps really need a temperature of 60 or higher to really give you good results. There was a chart on here once that showed the outside air temp vs btu's produced. With 60 degree temp you will not be getting the full potential. It will take 80 degree outside temp to get to the full 125kbtu output
Sent from my SM-N910V using Tapatalk
