Thread: Need to replace pump timer
    jtemplin3's Avatar
    Jul 2013
    Michigan
    6
    I am entering my 4th year of pool ownership.
    I have come to appreciate and rely heavily on the knowledge and support from TFP
    I am on a tight budget and need to manage energy costs where possible.
    Presently I need to replace the existing pump timer.
    It functions (dial rotates), but is missing the "dial tabs" to actually switch the pump on/off. I had submitted pictures previously and the only tabs I could locate would not work on this timer.
    I dont need any thing fancy at this point just functional
    What considerations need to be taken?
    25k+ IG irregular Marcite 1980, owned since Dec 2012, StaRite MAX-E-GLAS 3/4hp motor/pump, Hayward S-240 sand filter, Hayward Vari-Flo 710x32 valve. Hayward Heater (pass-thru only). 2 skimmers w/socks, single main drain, Nautilus Dolphin DX4 in 2014.
    liquid Cl 10-12%, liquid MA 31.45%, granulated CYA 96%, well-water.
    TF-100, SpeedStir, K-1716 Iron test, K-1730 Copper test
    Jun 2014
    15,285
    Re: Need to replace pump timer
    Shame you can't just get tabs. But if you end-up replacing the entire timer, many folks stay with the Intermatic:
    T101M (110)
    T104M (220)
    Hope that helps. Good luck!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    The timer dogs should be available. See if there is an ACE hardware nearby. They can order them.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I bought a bag of them at A local pool store with varied sizes. I'm sure they can be ordered online also.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
