Results 1 to 17 of 17
Thread: Stretch this back in track?
    Apr 2016
    Lexington
    55
    I'm not even sure what this is called. Anyone know how stretch it to get it back in? I've tried a hairdryer, but I don't think it's stretching? Any advise?
    Thanks!
    Lexington, NC, 24 ft Above Ground, Vinyl Liner, Hayward Sand Filter, Hayward 1 HP Pump, Tablet Chlorinator (use Tricholr), Taylor K-2006 test kit, County water.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Stretch this back in track?
    Nope. But, maybe this will help, Liner out of track A-B-Cs
    Apr 2016
    Lexington
    55
    I read that one, and was actually able to get my liner back up using those tips! But this isn't the liner and it won't stretch the same?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    HOT water (do not burn your self) poured over it with quick hands to push it in...........with gloves on to protect hands.
    Hair dryer-------one holding hair dryer while other works what ever it is back in.
    Kim
    DFW, TX
    24,497
    Hair dryer and pool?!?
    Jul 2012
    Tallahassee, FL
    30,525
    Quote Originally Posted by pooldv View Post
    LOTS of care and slow movement!!!!!!!!!!!!!! I know that is why I started with hot water!
    Kim
    Apr 2016
    Lexington
    55
    Thanks all! I was able to get the liner back up & in track using boiling water & a hairdryer, but I can't get this piece. Anyone know what it is/does?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Not sure if you're uploading or linking an image, but it doesn't seem to be working. Check this out:
    Posting Photo's Tutorial
    Isolated Spa - 345 Gallons
    Apr 2016
    Lexington
    55
    Quote Originally Posted by JVTrain View Post
    Thank you! For some reason it shows on my phone, but not on my desktop? I'm tying it with Flickr...
    Pool | Flickr - Photo Sharing!
    Jul 2012
    Tallahassee, FL
    30,525
    It showed for me when I first looked at it but now it does not. WEIRD!
    I am only guessing but could it be a "gasket" or seal to keep water out from behind the steps? What does where it go look like? Open, closed, hole, ????
    Kim
    Feb 2014
    Central Minnesota
    5,080
    Looks like it is supposed to fit into that track between the coping and steps? Does it seem like the gap is too wide and the strap/tubing is not being wedged in there? Perhaps the gap has gotten wider and is not holding the spline tightly enough? If so, I would look into trying to get a larger diameter spline or wrapping your current spline to make it larger? Seems like a similar application to putting new spline in a screen door/window but I could be waaaaaay off base here.
    Apr 2016
    Lexington
    55
    Thanks all! I don't think that the gab got wider, it snaps in good, just not enough slack, it's so tight.
    Apr 2016
    Lexington
    55
    Could it hold the wiring for the lights? It's got a Pentair lighting system.
    Nov 2011
    Moberly,MO
    1,010
    That is the fiber optic rope lighting.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2016
    Lexington
    55
    Quote Originally Posted by swimcmp View Post
    Thank you! Any clue how to get it back in the track?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by TyroBullmastiff View Post
    Perhaps soften it in boiling water and grease it up a little?
    Apr 2016
    Lexington
    55
    Thank you! I will try it. I need another inch or so��
