Thread: Cloudy Water
    Cloudy Water
    Good Morning guys.
    We have finnaly used the pool, my 7 year old invited his friends back from school Friday afternoon and the smile on his face said it all ......... well worth the months of work and expense, I jumped in myself friday night at 10pm as I put the heater on Thursday morning, pool was 26 degrees.
    Everything was fine and then god knows why but yesterday I thought it need a little more PH+ according to the test strips. so while we had lunch I added some, DISSASTER ! pool has now gone very cloudy (it was crystal clear before).
    I called in a good friend last night who has been around pools a long time and he has a proper testing kit.
    He advised I needed more PH+, and had touch too much chlorine (so I took the puck out last night) so I went off to the pool center and purchased this morning. Last night I also gave a small shock. no change this morning so I have added the PH+ but water seems cloudier now than ever before.
    Everything I have read suggests too much PH, test strips suggest ok to needing maybe a little.
    What should I do next ?, pool is 24 degrees approx and friend suggested that is why I can now see the effects of the PH+ as before it was only 13 degrees.
    Advice please
    Regards
    Paul
    Paul Jennings .....Kent ... UK (cold or colder)
    16ft x 4ft Intex 5000 gallon above ground pool, 32" x 16" Doughboy sandfilter, Doughboy 3/4hp pump, 9kw Elecro heater, 11/2" pipework, 400 micron bubble cover.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cloudy Water
    Welcome to TFP!
    There are many reasons for cloudy water, but any solution starts with knowing a complete set of test results.
    Re: Cloudy Water
    Agreed I understand that.
    Perhaps my question should be then, Can the pool be cloudy and not have enough PH ?
    Things appeared to go wrong when I added PH+
    Regards
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Cloudy Water
    Jason posted this after I asked him about high PH and low TA levels a week or so ago ...
    No, neither low TA, nor high PH, nor the combination will make the water cloudy. Almost every time, it is algae, both living and dead, that makes the water cloudy.
    It would help if could post a full set of test results so we can see where you stand with your water, but I would bet your on the verge of an algae bloom at the moment and shocking will clear it up ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cloudy Water
    I would advise you to get a good test kit, like the TF100 or the Taylor K-2006. Strips will always give you inaccurate results and you are just guessing at this point about what your numbers really are.
    At first I was like 26 degrees! Shiver! Then I realize you mean Celsius.... Still too cold for me
