Thread: coping and tile removal
    Jan 2016
    Wayne New Jersey
    17
    I have a tile contractor working on removing my tile and coping now . The electric hammer they are using is chipping the bond beam
    while they are removing the cement that held the coping tile in place is this normal ? I don't think so some of the chips are large.
    45,000 gal gunite
    with spa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: coping and tile removal
    How big is large? Some chipping is unavoidable and any loose material or areas needs to be removed for proper adhesion of the tile and coping. Any voids will be filled with the material used to set the coping and tile. It is most likely fine. Got a pic?
    Jan 2016
    Wayne New Jersey
    17
    I will try to upload a picture the largest chip is little big than my hand about 2 inches deep and several smaller ones . Thank You for the reply.
    45,000 gal gunite
    with spa
