Thread: Rusted stabilizer rails
    Apr 2016
    Owensboro/ ky
    2
    Having to replace my overlap liner because of metal flakes have roped it while vacuuming. Noticed the stabilizer rails are rusted. My 3 local pool suppliers do not stock or get the rails. One said I do not need them at all. So the question is are these needed? If so where to get them online. If I switch to the beaded liner are they needed?
    Kmstevens
    24' round above ground pool.
    using salt water system
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Rusted stabilizer rails
    They are needed. Even if you get a beaded liner you will need something to hold the liner.
    Do you know what kind of pool you have? That is the place to start. Once you find that out I bet someone can help you get to the right place.
    Kim
    Casey's Avatar
    SW PA
    10,448
    These stabilizer bars also help keep the pool round. I've never heard of a pool being installed without them.
