Thread: No Pool Light
    Apr 2016
    Monroe, LA
    3
    No Pool Light
    We bought a house with an existing pool but it has no light installed. We have tried Flolights which work well but don't last long. We are simply looking for a good option to light our pool and don't want to drain the pool nor go through the expense and hassle of installing a traditional pool light. I do have what seems to be a port (currently cover by the liner) in the middle of the pool that was possibly put there for a pool cleaner. There are also two pipes near the filter that are capped. One seems to be about an inch in diameter and the other probably 3". A) Is there an option anyone knows about to run a line through that booster pipe for a light and B) Are there any other options I have not thought of? We have also looked at floating lights but you either have to keep replacing batteries or recharging them or if they are solar powered they are disco lights. We just want a good steady light and not a 70's show. Thank you
    30,403
    Re: No Pool Light
    Welcome to the forum. Above ground pool or inground?
    Apr 2016
    Monroe, LA
    3
    Re: No Pool Light
    Sorry... inground pool. 18x36 with diving board. 3 returns plus two in the stairs
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,406
    Re: No Pool Light
    What about pretty pole lights outside of the pool? There are some pretty ones out there! Here is one example. I bet you could find others for a better price.
    Livex Lighting Frontenac 3 Light Outdoor Post With Lights in Black 7710-04
    Kim
    Apr 2016
    Monroe, LA
    3
    Re: No Pool Light
    Hi Kim... thank you for the post but we are looking for underwater ideas to illuminate the pool for night swimming and just general ambiance.
    Jul 2015
    Central Valley CA
    1,107
    Re: No Pool Light
    If the cleaner pipe is at least 1.5 inch you can go with a Nicheless light but the pipe would have to be straight at the pool for 3 to 14 inches at the pool for the light to fit depending on the model. Take a look at page 4 and 6 of this link. Also they are not cheep and while I don't know what moddle I have I will say we have 2 and I would consider that a minimum not sure how effective just one would be. http://www.jandy.com/~/media/zodiac/...h/h0532600.pdf
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
