Thread: Please help with plumbing repair
    Mar 2009
    Charlotte, NC
    539
    Is there a way to permanently seal the hole where my automatic chlorinator broke. I never use it. It is a relic from prior to TFP.
    Do they make a plug or is there a way to permanently seal it somehow without cutting pipes? Am I correct that the part that broke threads through their and so perhaps do they make a plug?
    If I must cut pipes can you coach me on unscrewing where the vertical part meets the 2 fittings on the pump?
    I assume that both of those 2 lower fittings can be unscrewed?
    Now that I think about it, just replace the piece that broke even though I don't use it? I assume the chlorinator fills with water or doesn't matter if it fills with water?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Please help with plumbing repair
    You might try removing the fitting that's broken and install a stainless steel screw from the inside of the fitting to the outside coated with silicone sealant and reinstall.
    OR .. with the broken fitting removed clean and rough it up with a little sand paper and use a two part epoxy to seal the hole, fill completely and have a "head" like the screw on the inside of the fitting and reinstall it.
    You could also use a different clamp with rubber that seals the same way and would just fit over the opening. Check out a hardware or box store and try to find the "old guy" who would know.
    Solar Blanket, Well Water, Borax Added. 76
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    If you are comfortable with it, or have someone who can help, it looks MUCH easier to me to just re-do some of that plumbing entirely!
    You have a threaded to slip fitting at the pump, and two elbows. You'd also need a coupling after that second elbow, wherever the PVC gets cut. I'd just cut it out and re-do it. PVC cutters are easy to use and many here could help with that as well.
    Kiss4aFrog answered what you asked more directly though, lol. I just don't see it as being worth all that effort for something that would be more likely to fail compared to just re-plumbing a little. I know you asked about avoiding cutting, but it looks like it would be much easier to me.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Mar 2009
    Charlotte, NC
    539
    Thanks for the help.
    Turns out I have the parts from an old kit.
    Any tips or tricks to pry out the old fitting that inserts into the PVC 1.5inch pipe? Just gently with a screw driver
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    It isn't possible to separate glued PVC fittings.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by Johnny B View Post
    Once the clamp is off, that other piece is just stuck in with hardened brittle rubber. I'd stick a screwdriver into the hole and jiggle things up-and-down and side-to-side to loosen it or perhaps make it disintegrate so you can pull the rest of it out. Just be gentle, because PVC pipe can get brittle with age, too.
