Thread: Pool replacement lights help/question
    Nov 2015
    Ok ok
    823
    Since my pool is empty getting ready for plaster, and I've never owned a pool before, I went ahead and took out a couple of lights so I could see exactly how things work. I am thinking of switching to LEDs, and also a salt water generator. As you can see from the pictures, it clearly states freshwater only. Is this a problem, or is it just something they put on standard or will a SWG cause me a issue? Also, this is far is I tore into them, I am guessing if I continue to remove the cover the light just screws in and out? I guess my biggest concern is salt water. Thx
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Nov 2015
    Ok ok
    823
    I did not want to take this gasket off for fear it might be one piece, do you know if this comes off and if the bulb screws out? I find that hard to believe the bulb is not removable and you would have to fish wire to replace a light?
