inground pool set-up and need assistance with pressure and suction. Pool filter is running at 12.5 psi
and pool pump is not providing enough suction. Also, any idea what the pipe with
no cap coming out of the ground is? I think its for the main drain. In the skimmer, i have
two holes with a flap on left. the suction in the skimmer is hardly noticeable and its
not enough to work a vacuum. The main drain may be capped since i see no movement
with leaves on the bottom. Any help would be appreciated.
