Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Help Identifying Substance in Pool
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Anyone have any idea what this could be in the bottom of my pool? At first I thought it was sand from my sand filter, but when I try to scoop it up it scatters like dust. Is it algae?
    It vacuums up fairly easily but I haven't vacuumed for a week so that I could see what this stuff was.
    11,500 Gallon IG Blue Hawaiian Vista Isle Fiberglass Pool (January 2015), LED Light, Jandy AquaPure Ei SWG, Jandy FloPro 1.0 HP Single Speed Pool Pump, Jandy Pro Series Sand Filter - Top Mount - 22", Polaris Vac-Sweep 280 pressure-side pool cleaner, Polaris PB4-60 Booster Pump, Jandy Never Lube 3-way Valve, Brushed Concrete Coping and Deck, Taylor K-2006 Test Kit, Taylor K‑1766 Salt Water Test Kit, SpeedStir
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Help Identifying Substance in Pool
    Do you have any ducks around?
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    No. Completely fenced in backyard with NO trees .. just surrounded by grass.
    It "speckles" on my tanning deck as well through out the swimming season. But like I said, it easily vacuums up so it's not THAT huge of an issue, just a nuisance. Could it be sand even though it scatters like dust when I attempt to pick it up?
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Here's a closer look ..
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    just looks like some dirt accumulation over time.
    If you test for combined chlorine and it's zero you know its not algae.
    Here in my region it's POLLEN TIME!
    Been vacuuming it up every other day for a week.
    Dolphin E10 Cleaning Robot.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Just a side note here. You can have zero combined chlorine and still have algae.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    You can?
    How would that be possible?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Absolutely you can. My pool is proof.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Bump your FC to above 10 and perform an OCLT. Do you brush your pool regularly? (Bottom and sides)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,424
    Use a turkey baster and suck some up. Put a white paper towel inside a colander and and squirt it out gently. See what color it is and what it feels like. You can also allow it to dry and see what it is like then.
    Kim (I think it is dirt but.....)
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    Quote Originally Posted by AimeeH View Post
    Quote Originally Posted by borjis View Post
    You can?
    Yep, Aimee is correct.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Thanks for everyone's input! Pollen does sound reasonable being in South Louisiana .. been hovering between 75 - 85 here lately. I also like the idea of sucking some of it up and putting it on a paper towel to see what I get... stay tuned!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    True that!
    Quote Originally Posted by wjr75 View Post
    HA! It does look like duck poo.
    30,403
    This thread is seriously lacking some current test results and nobody has asked for them.
    JcSparky, can you post them up for us? Without them, everyone is just stabbing guesses.
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Certainly .. I will do that this weekend .. between the glimpse of The Masters, of course. Thanks again!
    I’m thinking possibly mustard algae.
    Support the site
    Jul 2012
    Tallahassee, FL
    30,424
    DOH!!!!!!!!!! Sorry about that boss! I will do better next time.
    Can you also tell us how you are testing the water please?
    Kim
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Will be testing using the TFP method .. Taylor K-2006. Hope to have results today sometime.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Someone suggested an OCLT, lol.
  20. Back To Top    #20
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Results are in. I have been running my pool pump between 11 AM and 4 PM each day for a couple of weeks now. The SWG is set to max output. My current water temperature is 75 F degrees. The pump had been running 2 hours when I started my testing around 1 PM.
    FC : 2.2 (interesting so low given amount of salt and max output of SWG)
    CC : 0
    PH : 7.6
    CYA : < 30 (dot never disappeared)
    TA : 60
    CH : 80
    SC : 4200 ppm (optimum for my SWG) .. salt level for those asking
    Fire away!
