Thread: deep end a bit cloudy
    Mar 2016
    Winter Springs, FL
    5
    just finished with mustard algae 7 days ago and left with a bit of cloudy water at deep end. water a blue tint and has a white gray silt on steps and pool bottom that is swept each morning. just moved from test strips to TF 100 test kit yesterday. here are the results:
    FC 5.5
    CC 1.0
    TC 6.5
    PH 7.2
    CYA 60
    TA 120
    CH 300
    Should I slam the pool?
    Thank you,
    Alan, Winter Springs, Fl
    In ground 18' x 40' rounded corners, 3'-7.6' deep, 23,900 gals, plaster, C1200 cartridge filter, county water, Pentair 1hp model WFE-24 pump, with screen enclosure
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: deep end a bit cloudy
    I would just jump right into a SLAM, if you caught it early should be nice and easy and fast. cloudy water and 1.0 CC probably means you got a bloom starting. with the water warming up for us in Florida right now, gotta keep an extra close eye on the pool
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jan 2012
    'burbs of Augusta, Georgia
    7,285
    That 1CC means you still have something lurking in the water. I'd review the SLAM directions again and go at it.
    You're not done with a SLAM until overnight loss is <1, CCs are less than 0.5, and water is *clear*.
    pH is perfect for a SLAM, because once you start and raise that FC over 10 your pH test is unreliable.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by ach0g14 View Post
    FC 5.5
    CC 1.0
    TC 6.5
    PH 7.2
    CYA 60
    TA 120
    CH 300
    Thank you,
    Yes. The CC of 1 along with dead algae settling out and the cloudiness all point to a SLAM.
    Do whatever you can to improve water circulation in the deep end -- open the main drain, point a return down, or set the vacuum in the deep end tilted sideways so it pulls a lot of water -- and do not skimp on brushing. If you haven't pulled the light and cleaned the niche, do that, too. And check ladders, stairs, even the skimmer throat for algae. Some interesting pictures:
    Think I may have found my FC demand issue?
    Problem Found and Ideas needed
