Thread: retrofit of auto-fill
    Houston, TX
    1,107
    Hello to All,
    Our pool was installed last Aug-2014-March 2015...we knew to have auto-fill installed.
    I have 3 diff n-bors that had their pool installed at time of house construction...makes sense, no hassle of having the pool built when you are there. But, the builder did not install any of them w auto-fill. I left to take daughter to airport this morning at 4am CST. Saw water coming from neighbors backyard drain to street...saw it again returning at 630am so I called him...he turned on his water at 830 last night to fill his pool and forgot...that's going to be an expensive bill
    N-bor next to me that moved to Canada per his company...has not sold his house since July 15...guess what n-bor was his autofill for 5 yrs...told him to get it a long time ago, but he did not...he hired a pool m-man when he moved out, his comp bought house 14 days ago and let his pool guy go...guess what...Pentair VSP burned-up this morning...guy behind me has same problem. As a good citizen, I called him when his pump was cavitating and his wife immediately filled pool...
    So, what is the best method or options for retrofitting a pool w auto-fill ?? I have 3 prospects for someone to install them.
    regards, tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Apr 2013
    Sacramento, CA
    2,769
    Re: retrofit of auto-fill
    Retrofits can be difficult because you generally need a location near the pool to install the auto fill. If you have a suitable location then its relatively simple. But even then it could be costly. Say around $1,000 to $1500.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Some people have built hose mounted auto-fill devices from either cattle trough fill cut off floats or a common toilette cartridge float with a PVC pipe U to bottom feed it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    At the very least everyone using a hose should use a hose timer.
    Shop Orbit 1-Program Digital Hose End Timer at Lowes.com
    Houston, TX
    1,107
    Thank you for your answers...I'm trying to get all these people going in the right direction....rgds, tstex
