Thread: Pentair Intellichlor IC-40 SWG setting
    Oct 2015
    Houston, Texas
    14
    There is a setting percentage for Pool and one for the SPA. Should I just worry about the pool setting and keep the spa setting at 0%? I have it set at 40% now for the pool.
    22 x 36 ft. in ground Free Form Salt water pool; 8 x 8 raised spa; 3 ton Mossrock waterfall with its own Pentair Whisperflo 1.0 HP pump; Filter 60 sq ft Pentair FNS Plus D.E. Filter; Pentair Whisperflo Pump 2.0 HP for pool; Pentair MasterTemp Natural Gas Heater, 400k BTU; Polaris 280 w/ booster pump; Pentair Intellichlor IC40 Salt System; Ozone Joe Water Purification System; LED lights; bubbler on sunshelf
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,460
    Re: Pentair Intellichlor IC-40 SWG setting
    If you have the EasyTouch, it automatically reduces the IC40's chlorine output to about 10% of whatever the pool output is set to when you select Spa. Not sure how this would work without the Automation.
    Oct 2015
    Houston, Texas
    14
    Thank you
