Thread: Aqua Rite Electronic Chlorine Generator
    Apr 2016
    Parrish/FL
    2
    After reading previous posts where the power light would not come on, it was recommended to replace the current limiter, RZ3. I did this and the power light came back on with the Generating light on as well. Went back to check on it and now the diagnostics reads p c b and the power light is on along with the no flow, check salt, high salt and inspect cell lights on steady. I installed the resistor the same way as the old one and had taken a picture of my connections to ensure I connected everything the same as before. Any thoughts? Thanks.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Aqua Rite Electronic Chlorine Generator
    Bump Bump Bump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to the site, from the manual it says the P C B your seeing that you need to contact the company.. It looks like the fix may not have fixed it.. wish I could help more..
    "-Pcb-" displayed and all 4 red/yellow LEDs are illuminated.
    A possible Printed Circuit Board fault has been detected. Call for
    service.
    https://www.hayward-pool.com/pdf/man...-AQR-Owner.pdf
    Apr 2016
    Parrish/FL
    2
    Thanks, I was afraid of that. DOH!
    Florida screened in, in ground pool, approximately 13,500 gallons with solar heating
