Thread: Solar Covers
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Solar Covers
    Anything new out there that lasts longer than 2 years? Does anyone make one out of thin bubbles (like 1/8")? I bought some of this to wrap around my 15g chlorine tank: InfraStop 24 Double Bubble Reflective Foil Insulation - Automotive Fuel Tanks - Amazon.com It's very nice and works well at reflecting heat. It's like 1/8" bubble with foil on each side. I'm thinking this bubble but with no foil would work well as a solar cover (mainly for lighter weight and maybe cheaper).
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Solar Covers
    I went with the thick 16 mil one before I knew better, I can say the pool went from 60 to 75 degrees in 3 weeks with the mean temp about 60 degrees here..
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Solar Covers
    Some people have had luck with thicker covers lasting longer but I have tried 5, 8 & 12 mil covers and they all seemed to last the same amount of time. So now I just buy the cheapest (and lightest) cover I can find on eBay. The last one I got was 5 mil for less than $80 (actually two AG covers) and it is about to hit the two year mark and it looks like it is nearing its EOL.
    Mark
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Solar Covers
    Anyone try the small 3/16 packing bubble wrap? Comes in 4', 6' widths. Would be easy to make 3 or 4 rollups. I have 12' sections of 12 gauge now, and it gets heavy.
    DIY chlorine feed
    BBB
