Thread: Best way to get started
    Josh_Leatha's Avatar
    May 2014
    Lahoma, Okla
    64
    Question Best way to get started
    So this is going to be our third attempt for having fun and clear AG pool this summer. We've not had very good turn outs and last year I found this group and learned about the BBB and slamming methods...... Now I need help to see what is going to be best at getting the pool cleaned and going. We didn't close it or cover it this past year so my husband took it upon himself to start draining it while I was gone one day so now it's got about 1 1/2 foot of water in it and I started slamming it to clear it up so I can see the bottom. I need to know if it's best to start cleaning it by vacuuming it over the side cause I can't use the pump or do I slam it and just fill it back up while keeping it slammed....
    32,000 gal, 33x52 AG, 300lb Cristal-Flo II sand filter 145362C, 2 HP Dynamo 2 speed pump DYNII-N2-2, Install date June 2012, bought house Jan 2014.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Best way to get started
    If youve gone that far, you ought to clean it out as best you possibly can now, refill and properly SLAM it when it's full. If it were mine, that's what I'd do.
    Essential Links:
    May 2014
    Lahoma, Okla
    64
    Thanks Patrick_B that's what I needed to know. Wasn't sure what is best and easiest to do.
