Thread: Converting to SWCG--Chemistry Questions
    Aug 2013
    Otsego, MN
    79
    After years of doing TFPC/BBB on my various Intex AGPs with bleach, I've decided to convert to a SWCG this year, along with a sand filter system. My Intex 633T filter pump has run great, and is certainly an upgrade from the one that came with the pool, but the cartridge maintenance just gets really old.
    Anyway, here's what I've purchased:
    We have well water with clear water iron in it, so I fill my pool with water that has been run through my water softener to remove the iron (otherwise, adding bleach to my hard water causes the iron to immediately precipitate out of the water and makes my pool look like a mud bath). As a result, my CH numbers are pretty low. Also, our well water is very alkaline.
    Typically, my soft water CH runs <10 (solution starts out purple--not red--and one drop of R-0012 turns it blue), and my TA usually starts the season around 380-400.
    So, my questions as I begin to prepare for installing the new equipment this spring are:
    • With my TA typically so high, how aggressive do I need to be about lowering it? The "Water Balance for SWCGs" article states that TA between 60-80 is "IMPORTANT."
    • With my CH so low, do I need to bump it up? The same article says CH for vinyl lined pools should be between 50-300, but also says, "don't add."
    • If I need to adjust these things, do I need to do so BEFORE firing up the SWCG? Should I just go with bleach until the water is balanced for my SWCG?
    Thanks for any help you can provide!
    EDIT: Also, this year, for the first time, I left the pool up over the winter. Which means I'm carrying over a little less than half of my water from last year. As a result, my TA will probably start out a little lower, as splashing/adjusting pH with MA over the previous summer lowered the TA in the existing water.
    Pool/Equipment: 20'x52" round Intex Ultra Frame AGP (~8,800 gallons)--Intex SWCG (CG-28669, 15K gallon model)--Intex Sand Filter Pump (SF60110, 16", 120lbs sand, 3K gph)--Hayward SP1091LX Through-Wall Skimmer--Hard Plumbing--Taylor K-1766 Salt Test Kit--TF-100 Test Kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Converting to SWCG--Chemistry Questions
    You will love a SWG
    The only issue I see is your TA, with it that high your PH will raise very fast, how fast is the question and you will need to keep up with the PH test.. So I would take your TA down using these directions Pool School - Lower Total Alkalinity
    I would add the salt and use bleach till you get close to the recommended setting before you fire up your SWG, then turn it on and monitor and see what your pool likes
    Hope this helps
    Aug 2013
    Otsego, MN
    79
    Quote Originally Posted by cowboycasey View Post
    You will love a SWG
    Hope this helps
    Thank you, Casey. OK, I'll plan to do my hard-plumbing of the system first, so I can install a fountain for aeration purposes, and work on lowering the TA before starting the SWCG. Or did you just mean to do the typical prep before starting the SWCG (adding salt, of course, and getting up to the recommended chlorine level with bleach)? I did plan to do that.
