Results 1 to 9 of 9
Thread: LFNC v PVC - Liquidtight Conduit for from junction box to lamp
    Apr 2016
    South East USA
    78
    Hi,
    I'm re-locating a junction box which runs to a lamp in a wet niche.
    I'll be splicing into the existing conduit from the lamp.
    The run form the jbox to the niche will be about 50 feet.
    I considering 3/4 liquid tight flexible non-metalic conduit (LFNC-B, not LFNC) buried at 18 inches under packed earth for ease of use.
    PVC is certainly a lot cheaper. Are there any other benefit of using PVC over LFNC?
    ft.
    ~22,000 gallons, freeform, Pebbletec, beach entry AquaRite SWCG v1.33 Hayward Tristar SP325EE pump for main draw & skimmer Hayward sand filter S310S 1.5 hp booster pump Paramount PCC2000 in-floor cleaner, skimmer, debris containment canister Waterfall Pentair Intellibrite 5g LED light in Pentair stainless wet niche Jandy Lite2 heater: removed Auto-fill: deactivated
    30,431
    Re: LFNC v PVC - Liquidtight Conduit for from junction box to lamp
    I do not know what LFNC is but that conduit typically isn't waterproof, anyway.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    That conduit is not permitted for burial. If it was, I would not suggest using it anyway.
    PVC conduit can be relatively easily bent or shaped. There are several tutorials on YouTube.
    I highly suggest using 1" conduit, it will make pulling the cord that much easier.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Apr 2013
    Sacramento, CA
    2,769
    Yes there is a benefit of using regular non metallic conduit over liquidtight. First, you can generally only bury liquidtight if it say you can. It must be listed and marked for that purpose. So look on the liquidtight it will say "direct burial."
    Next you need to understand that the conduit from the light niche to the junction box is special. It is designed to be wet and it is expected that at some point you will have to replace the fixture. and re run the cable. So it should be oversized, 3/4 minimum so its easy to pull through the cable and a separate ground.
    Finally most liquidtight is not used for long runs, its rough. Its difficult to fish wires through it if you are trying for a long run. Homeowners tend to allow it to bend and twist which adds to the difficulty in fishing wire.
    30,431
    I will add a big PLUS 1 for using oversize conduit. Pulling a 100' wire through a 3/4 inch conduit mess I made for myself nearly brought me to tears.
    Apr 2016
    South East USA
    78
    Quote Originally Posted by bdavis466 View Post
    LFNC is listed for burial and also concrete encasement.
    LFNC-B is listed for runs longer that 6 ft.
    Here is an example.
    ft.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    This is in a flooded application where it would be difficult to connect to the niche out existing pipe without having a leak.
    Its expensive and the benefits do not outweigh the disadvantages in this case.
    -Brian-
    POOL BUILD
    Apr 2013
    Sacramento, CA
    2,769
    Most industrial electricians don't use LFNC-B for long runs if they don't have to. Its expensive and I don't see someone without a lot of experience having a reasonable time pulling that much through it.
    It comes in rolls that can be difficult to get straight.
    Apr 2016
    Kankakee Il
    39
    I actually had to google it to see what it looked like. My take on something like that is if it Flexes, it has to give up some strength to do it. Would you rather a pool builder use rigid PVC or flexible PVC for plumbing? Is it acceptable, maybe, but why chance it? Rigid PVC has the tendency to pull really difficult with certain types of insulation, just use a little Aqua lube and it will pull like butter, also steel 90's help too. Almost forgot, a propane torch or weed burner can be used to bend it, they make special springs to use with a pipe bender, but that means buying extra stuff.
