Thread: Is Pebble Tech Considered Plaster?
    Jun 2014
    Roseville, CA
    343
    I found this in the recommended levels part of the forum:
    Pebble tech is not broken out so I'm unsure which applies here.
    I've become appointed pool expert to an additional two pools my kids have built. One is under construction, one is a recent new refinish - both are non SWG, one I may recommend borating because he has lots of trees.
    Thanks in advance.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Is Pebble Tech Considered Plaster?
    Yes. Plaster is what holds the pebbles in place.
    Jun 2014
    Roseville, CA
    343
    Got it. Thanks
    My Ideal Specs:
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Why borates? chlorine should be fine
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
