Thread: AG Pool Installation Help
    Jkinney's Avatar
    Jun 2015
    Millbrook/AL
    4
    Unhappy AG Pool Installation Help
    We're currently trying to install the liner in a 10K gallon 21'x52" saltwater 5000 round AG pool, from The Pool Factory. The problem we're having is that after putting the liner on it pulled two sections of the steel wall out of the bottom rail. Could this be due to the fact that the liner was not put out in the sun to warm up first or is it more likely that somewhere the bottom rail is not level? The liner is extremely tight and appears to have a 3 to 5 inch air gap between the wall and the liner. We've already measured and found the pool to be 21' round from every upright to every opposite upright. Also, we're using a 3" sand base with a foam cove and the bottom seam still sits approximately 2" above the cove. We've also double checked the liner measurements (21'x48").
    10K gallon, 21'x52" Saltwater 5000 Round AG, Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    30,426
    Re: AG Pool Installation Help
    My guess is it's a little cool this AM. I bet you'll have you best luck after lunch.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Yes they strech better when warmer. The seam on mine is also above the cove, the wieght of the water will push the liner against the wall. Before you fill it make sure the wall is the rail though.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jkinney's Avatar
    Jun 2015
    Millbrook/AL
    4
    Thanks!
